Transforming a 2002 into a E36- The build
rot62
  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
The E36 front struts I have were non serviceable units so these would have to be changed or upgraded. Since I already had installed koni shocks in the 2002 struts I decided to keep these and modify the E36 strut so the koni's will fit.
The plan here is to insert the 2002 tube inside the E36 strut. The bottom of the 2002 strut has be enlarged and then machined to be a tight fit inside the E36 tube. The top of the 2002 tube will then be welded to the E36 tube and then only the tread for shock retaining nut will be left sticking out the top.
New front cross member mounts
I cut 20mm off the old cross member mounts and then tacked on the new
plates which when finished will become the new mounts. The E36 front sub frame mounts are 100mm wider than the 2002 mounting points.
Is it going to fit? I had to take to the tunnel with a hammer- not the best way.
The engine's not going to fit on the cross member like it did in the E36. The 2002 engine bay is to small, so it looks like the engine is going to be 55 mm further forward. Which means the sump or the cross member, or maybe both is going to have to be modified. I think I will move away from this problem and come back to it later in the week.
For now I will work on finishing up the front cross member and control arm mounts. I will also have to install the sway bar mounts.
