Wunderbox diagnostic tool
jgerock
Just edited my earlier post to clarify. When are you coming to visit? Jessie and I brag about you and Athens, Ohio at least once a month.
Pat- thanks for the run down on the features of your box.
William
Hey William, it looks like the Endocrine Society's annual meeting is June 19 to 22nd in San Diego. As far as I know, I'll be there with a bunch of rowdy scientists from Athens. If you want to have a good time this July, c'mon back! http://www.ohiobrewweek.com/
Bring a Welder
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
San Diego can absorb the sailors of the Third Fleet, and visiting rowdy endocrinologists, but I'm not sure the town can survive both at the same time!
We'll be around, so hopefully get to see you!
72 BMW 2002tii Inka, Tip Top
92 BMW 318ic, Wolfgang
07 Mini Cooper, MC
72 BMW 2002tii Malaga - stricken
i didnt mean to steal your thunder..
i just thought this thing was out of print
hey id like to collaborate with you on another idea i have
you might be the guy to help me pull it off...
there cant be much to these things...im a half assed electronic hobbist. im sure someone with just a lil skill and a soldering iron could build one...
does any one know the pin out lay on the pull?
it would be fun to make one using a microcontroller
how do you think mine works ? it uses a 8k processor running at 8mhz.
it shows an entry text at power up...the button on the right is used to select the desired diplay, Volt, Dwell or tach. 100% digital.
got bolts?....well i sell them...ask me how....
bimmerboltsandparts.com
75 2002
88 yamaha ysr50 (street)
88 yamaha ysr50 project
94 jeep yj
84 318i
  • 1 month later...
  • 1 year later...
fwiw, i am getting this back on the work bench, i calculated real cost and i will most probably build 10 of theses, to get a cost of 100$ each.
I will make a stick-on faceplate to make it look nicer.
It will include:
-the box with a ign and start switch, and one led to show the ignition status
-4 digit LED display
-will show tach, voltage and dweel
-with 4' of wiring harness and the correct plug that goes on the 02 diagnostic socket.
note that the one pictured above has 3 panel indicator, onely one is used the 2 others are uselss.
The processor will be mounted on a socket so if there is eventual software upgrades, i will be able to upgrade with processor exchange by mail for modest fees.
If you are interested, let me know.
1985 XR4TI, 22psi ±300hp
I didnt gave much details, but there is also one ignition switch (the chrome togle switch) and a start button (the red one) so you can start the car remotely, or just tickle the starter, like when you adjust the valves.
Final design will differ a bit from the one pictured, the box size and the LED display will remain the same. Switch arangement/position and LED will differ a litle bit.
I received 6 confirmations today !
1-Jeff Taylor
2-Kevin Wickless
3-Charlie Gordy
4-Scott Sislane
5-Frank Greppo
6-Jim Gerock
If you are not on the list, shot me an e-mail.
regards
Pat
edit...i have 10 now !
1-Jeff Taylor
2-Kevin Wickless
3-Charlie Gordy
4-Scott Sislane
5-Frank Greppo
6-Jim Gerock
7-Bill William
8-Penth02 (joel)
9-Karl Kussin
10-John Morrison
