removable bell housing?
1972fritz
so i am trying to figure this out. an m30 has the same deck height as the m10 so is the tranmission bolt pattern the same? now i thought the m30 came equipped with the 260-265 with a removable bellhousing right? where can someone get one of these bellhousings with out paying out the a$$? and has anyone looked at using this with a t5 or t56 transmission?
The M30 bellhousing flange IS the same. Surely somebody's used one to adapt a different transmission. Seems like just the other day Toby B. may have posted a photo of something he's been working on along those lines.
Budweiser...It's not just for breakfast anymore.
Avatar photo courtesy K. Kreeger, my2002tii.com ©
naw, I chopped an old 2002 trans in half. It worked... sorta. I made
some other mistakes, so it needs work this winter.
The t5 is huge, and it has a lot of that mass above the driveline center.
When I find an M30 bellhousing in the cheap junkyard, I will
beat myself senseless to get it out and then see what can be done
with it. I predict it will need a LOT of tunnel work to get it in there.
Gordon put a Jerico in his, and his tunnel is quite gorgeous. And VERY custom.
Unless you're nuts, the 245 and a 3.9 or 4.1 gets you 90% of the
effect for 10% of the effort... and a 245-10 gets you 99% of the effect
for 10% of the effort and 400% of the budget. And less weight.
what I've found,
i am sort of crazy... as far as tunnel work goes thats fine. but how much chopping had to be done on the housing its self? sa far as size goes yes its bigger then lets say the stock or an e21 unit but i have seen cars rip through gears on cars with 700 wheel horse and get 100,000 plus miles! but its an idea i have to think of because im crazy and need to make things more difficult.
Actually, the hardest part is the welding and re- machining of the
cut 2002 trans.
The tunnel's just basic structural bodywork. You cut away what's going to
hit, add extensions to it, then weld it all back up.
But really, it's not worth it for a street car- the 245 ratios are just fine
for street work, and a 245 can handle anything an M10 head can flow,
including a pretty stout turbo. About the time the 245 is the weak link,
everything else starts to get marginal too...
Beyond that, well, get some parts and start cutting and welding!
heh
i am going to be running a very stout turbo and either a e30 rear diff or i have been looking at using another diff like a cobra unit or a bmw large case. so i figure with the time i will spend with all that stuff i might as well see about getting rid of all the weak links.
Then the WC T5 sounds like just the ticket for you. Get your hands on one
and have at it. I'll pop up again when I get my mitts on an M30 bell
and let y'all know how it looks.
I got all excited about Honda S2000 stuff and then realized, uhhh, why not
just race an S2000....
Unfortunately I don't have access to the lathe I used to make the adapter, I'd be happy to send you drawings and instructions.
If I recall correctly the box was a 3HP22 although anything from an auto M10 should work. Probably the hardess part was doing the clutch fork. In hindsight a hydraulic release bearing would have been easier.
I ended up using a modified Sierra fork with an E30 slave cylinder.
what I've found,
And the 240 gets you the all of the overdrive without all of the weight penalty of the 245. As long as you're not trying to push 200hp through it. :)
Tom Jones
No, I really won't swear to it.
This was last winter when I was working on
the Nissan tranny.
It's on my hit list, tho, and there aren't any
318 autos in the cheap yards right now.
But I'll keep looking, 'cause it looks a lot more
adaptable than what I've been using.
