Tii Performance
Keith02
Thanks for all the input.
The car is , and will remain, stock in appearance. I maybe give the Petronix a try.
All the suggestions are good. Modifying your tii's engine will make it faster over a narrower rpm, but at the expense of drivability and reliability. The pump can be recurved using a different fuel delivery cam, but that will take some money and a fair amount of time.
No one's mentioned MSD or Crane XL700 (if you can find one, IE still had them a couple months ago). According to Jeff Ireland, electronic ignition will make a noticable improvement at lower and mid rpms due to making multiple sparks on each compression stroke. At higher rpms, it doesn't matter as much.
As stated elsewhere, keep a set of points ignition in your trunk as backup to get home with. My Crane died and I was glad I had the spares.
Pertronix is electronic points - firing once per piston stroke at all speeds. It just doesn't wear out like points will, so replacing a set of worn points with new Pertronix makes a significant improvement in drivability.
Jerry
no bimmer, for now
For my 74 tii, I had the motor rebuilt to tii Euro specs, new pistons with 9:5:1 comp and that was it. Nothing to the cam, etc... Like several persons on this thread said, you can't mess with the fuel delivery system on a tii. Other than getting the motor rebuilt, I have polyurethane bushings, Bilstein sports, Eibach springs, ST swaybars, 5 speed and a LSD. BTW, the exhaust is stock.
G-Man
74 tii (many mods)
91 318i M42
07 4Runner
You saw no difference in performance with the super sprint header vs
stock exhaust manifold ?
No difference in the amount of fun i have driving my car. I think the difference was neglibile in comparison with the stock tii setup. With carbs or efi where the 4500rpm range could be adjusted to add more fuel I think you'll see a gain in power at part throttle- but for me lean is fine there.
I would however like to believe that the rest of the supersprint system- res and muffler- are worth getting in terms of a less restrictive setup because I shelled out for it.
The other mod that you could do- and just about the only internal one possible to fit the stock fuel curve- is higher compression pistons. That modification will not affect the fuel curve but it would require higher octane gas and most likely would benefit from have the dizzy re-curved.
That makes sense- the restriction is after the y- pipe on an
otherwise- stock exhaust...
