trunk plugs
robsanab
any one have a good alternative and/or what is the part number for that oval plug (2 of them) at the top of the trunk... mine were gray... seemed to have lost both of them.
the oval hole is about 1-1/4 x 2-7/16
Rob
1966 Mustang vert - 5.0EFI/AOD & mods
1975 '02 - the typical upgrades (my 'new' car)
well, CD if that is it I assume you mean item 6... the only oval plug?
AND Matt, if it is item 6 then Max shows them as available for 7.50 each... BUT it also shows a quantity of 4?? there are only two that I know of... therefore I'm not sure if these are them or not.
anyone shine some light on this mystery... being halloween and all?
Rob
I have read the listing in the parts book (paper, circa 1972) the description of the plugs for the trunk sides, when translated from German (via babbelfish) "special equipment sunroof"
RK in OC
ex- 67 1600ti/Aplina
http://rogerspeed.tripod.com/bmw_1600tialpina/
83 A/R Spider Veloce
"I come from a broken home, I should know, I broke it" Bazooka Joe
  • 9 years later...
SUPER THREAD REVIVAL!
looking into this . my car came with NO A/C and WITH SUNROOF
do I just need the plugs or do I need the vent tube as well? I see the wholes for both in there. but not sure what the function is if any at all.
any advice would be great.
thank you@!
Love it. After nearly 10 years of dormancy, the thread lives again!
A/C has no bearing on what you need. Cars without sunroofs had (marginally-effective) flow-through ventilation. Cars with sunroofs did not, as the negative pressure would make the headliners balloon.
So you need plugs, but not tubes, since you have a sunroof. Of note, many sunroof cars actually came equipped with tubes, but said tubes were plugged with foam rubber at the factory, to render them inoperable.
Edited by Conserv
