Auto trans question...
TobyB
well, actually, bellhousing...
What's the 'thickness' of an auto bellhousing?
As in, if you unbolted it from the engine and transmission,
flopped it engine- face- down on a flat surface, and then measured from
the flat surface up to the transmission- mounting surface?
Thanks!
Hell, no, I shan't explain, for it is
YOU are not WORTHY, my good
NON 2002 owning POSTINI!!!
hee hee...
CD, I do love you, but why not say that you just don't know?
And anyway, 3m stuff is every bit as good as Wurth, and a
darn sight cheaper... and easier to find...
Here's a picture or 2 to gross you out.
(Gordon, you're close, but a Quaife would eat up next season's
entire shrimp budget, if you know what I mean?)
ps, if anyone knows the actual dimension, I'd be grateful! The victim is
far too lengthy to be easily adapted...
Toby,
I don't actually know your answer but I do know its been discussed here before. I think the guys were discussing how Jensen Healys used the same Getrag CR box with a different bellhousing so the post had all the dimensions up there...
I know (or I think) ToddK was involved in the post, possibly try searching his user name and "Jensen"???
I'm at work and have limited FAQ'ing abilities here with internet filtering and all...
What gearbox is the donar?
E36
Yup, it's in fact Japanese...
Alp would be able to guess, as he has one (or 6) of 'em...
It's a Nissan from the late '60's. The ratios
(with a 4.44 diff) are pretty darned good for a 22" rear tire
and a motor that doesn't wind past 7500. And when I do,
the later Nissan boxes have the same bellhousing, so 'gear' changes
will become 'gearBOX changes.
AND it'll work with a 1- piece, dry driveshaft. It's so good a fit
you'd think it was made for it. Well, except for the bellhousing...
So I need a bellhousing for it, with a short (145mm) depth.
When you mill the back off a standard box, you kind of run out
of aluminum about 160mm... and I was trying to find out if
it was worth chasing down the auto housing or just setting to
work with the tig.
The auto cars do show up in the cheapo junkyard from time
to time, but (as it alwasy happens) there haven't been any there for a
while. I may have to range farter...
Winston, the Jensen discussion got close to the answer, but never
made it there... good memory, though!
Right on, Gordon-
that's this weekend's project!
Well, maybe next weekend- I need a boring head
to mate the adapter plate to the donor transmission...
You do know, though, that I'll be slower after I do this?
And here's the link to Jerzy's answer, since it won't search as well as this thread:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,viewtopic/t,312743/
