Leaking Weber 40DFAV carb
schuetz1619
On my 74 2002 I have a Weber 40DFAV carburetor that I love, but when
we put it into the garage there has always been a gas smell. I have replaced the manifold-to-carb gasket, checked the float level, and installed lock washers under all screws as well as under the four carb-to-manifold
manifold retaining nuts. I still have the smell.
I then cleaned the carb and manifold so as to see where the leakage
is coming from. It appears to be from both ends of the throttle
shafts, as demonstrated the staining of gas running down onto the
base and manifold on both sides of the carb. Also, when I put my fingers under the linkage cover after stopping the engine, they came up slightly moist.
10,000 miles ago, assuming that the problem was wear of the shafts/races, I sent the carb to a carb shop. After disassembly and measurement the shop returned the carb to me untouched, saying that the shafts and races were within tolerance and that shaft replacement and rebushing would not improve on what I already have.
All of this said, the carb still leaks from the throttle shafts and
my wife won't permit it to be parked in the garage because of the
smell. Now the car, with its $5000 paint job, sits outside for the winter. Does anyone have any ideas before I spend $500 on a new 38/38?
replace the float needle valve with rubber tip
and ' stake ' down the brass needle seat that the needle
seals into. If the brass seat has come up abit, that will
also cause a false float level setting - possibly over flowing
float bowl, when the motor is off and 'heat soaking' .
Measure your float level after repair.
Your not using some high pressure electronix fuel pump
are you ?
Your WEBER "Needle & Seat" part number
is : 79519.______ , the 3-digits after the ._____ is your needle/float
calibrated size. It's available in 79519.125 , .150 , .175 , and .200
Look closely at your float for stamped numbers or measure it.
'64 R27 250cc #383851 18,000m
Thanks for the advice.
I have rebuilt the carb twice—most recently 5000 miles ago--both times with original Weber parts (including the needle valves with rubber tips). The seat is the machined inside top of a cylinder that screws into the carb cover. It is seated tightly, but I have no torque figure for it. Not sure how it could "come up." In any case it is tight and not going anywhere.
I am using the OE mechanical fuel pump.
I think I'll try purposely misadjusting the float in the direction of less gas and see what happens. I'm at a loss otherwise.
______________
are you ?
... and my wife won't permit it to be parked in the garage because of the smell. Now the car, with its $5000 paint job, sits outside for the winter. Does anyone have any ideas before I spend $500 on a new 38/38?
Doesn't the gas smell go away after the car cools down? Leave the car out until it's stone cold, then roll it in and save the $$$ paint job.
Bob
BMWCCA #4844 (#297 of The 308)
1974 2002 Sahara, MM 2400 Rally engine, MM 5 speed and conversion
1976 2002A Anthracite parts car
1991 525i AlpinweiB II
2002 330ci AlpinweiB III
2007 530xiT Titanium Silver
What kind of air filter do you have? Open K&N type? Plenty of gas smells from one of those. Also, how are the hood seals? Are toe ones on the side by the hood hold down rod in good shape? What about the one on the hood itself?
CD is probably right.
John
1665778
