300 mile drive
BOBERL15
I just purchased a 1972 or 73 tii which I plan to drive from cleveland to chicago. The vehicle has not run in 6 months, short of fresh gas, an oil and filter change along with fluid and hose inspections is there any thing in particular I should look for or worry about?
Thanks,
Ben Oberlander
E-Mail ben_oberlander@yahoo.com
Seriously, your tires will prob. have flat spots which will vibrate thru the wheel. Check the pressure before you go. Take some euro fuses, stiff wire, jb weld and duct tape, which will fix most maladies. Check your lights and signals before leaving. The battery might not hold a charge if it is old, you might load test it before you go at an autozone. Fan belts are cheap insurance too.
Good luck!
Ben
--> 1968 2002 <--
A spare can of Brake Fluid may not be a bad idea either, as some of the rubber lines to the resevoir may have developed cracks and leaks.
A roll of electrical tape, sme spare wires, butt connetcors and a pair of wire crimpers would't be a terrible idea either. No telling what electrical horrors the PO inflicted on your car...
click signature above for my resto blog
Here is my list O'stuff I have in my tii.
Broke down on the 2005 Alpine(lost the FI pump belt), had the car back on the road in an hour or two. On the 2005 Melee and the 2006 Alpine, I was the one helping out other people. Carry the things that would leave you stranded, the parts you can't get at the local autoparts store.
2002 tii Spares - (New Parts)(in Small Bag)
Alternator belt
Cap 056
Condenser 292
Crush rings/O-rings
Fuel filter KL24/1
FI toothed belt
Hose- 6x11
Hose- 8x13
Hose- 12x18
Oil tube- K-fish to block
Points 044
Radiator cap
Rotor 215
Spark plugs W7DC
Strut mounting safety bolts & wire
Throttle body paper seal
(Good Used Parts)(Small Bag)
Alternator mounting bolt/nut
Battery hold down strap
Brake caliper pad spring & retainer
Brake lines
Brake res. hose & fitting
Bridging sleeve for heater core failure
Electrical tape
Electrical wire & connectors
Exhaust hanger donut
Flasher relay
Fuel lines rigid- tii
Fuses- ceramic
Hardware- misc
Hazard switch
Headlight
Headlight switch
Hose clamps
K-fish coolant hose
Light bulbs
Lug nut
Oil pressure sender
Plumber’s tape & bailing wire
Radiator cap
Relay- 4 terminal
Rubber mount for fuel pump
Spark plug & coil wires
Throttle springs
Tie wraps
T-stat emergency
Voltage regulator
(Big Bag)
Oil
Coolant/water mixed
Brake fluid
Starter fluid
Rain poncho
Space blanket
Flashlight
Rope
Rubber gloves
Leather gloves
Safety triangle
Safety glasses/goggles
Jumper cables
Rag
Paper towels
Chem. Lights
Hand cleaner
Lashing strap
Wiper blades
Manuals
tii air tube
Oil filter
Heater hoses
Battery post cleaner
Schrader valve tool
Plug socket and gap tool
Toolbox
(Small Box)
Coil
Distributor 002
Fuel pump
Gas cap
Shifter lever end (connecting pin & set screw)
Fire bottle (in car)
First aid kit
(Extra Rally Kit)
Wheel block
JB weld
Water jug
Air compressor
Tire repair kit
Snow chains
Oil
Block of wood for jack
Safety triangle
Steve J
& too many bikes
How much do you trust the seller? Or maybe you're already familiar with the car?
If I didn't know the condition of the injection (forget about the rest of the car for a moment), I'd take a carburator and intake manifold as backup. That way you won't get stranded - for too long...
Did someone say, "Road Trip?"
Just drove 2350 miles in my Orange Julius.
What I needed enroute was an exhaust system, some 8 amp fuses and new fuel pump.
I had the fuses, anyway...
Ben Thongsai's personal cell number is a good things to have, too. Unless you're out of tower range...
Delia
1973 2002tii - gone
Inka (aka "Orange Julius")
#2762756
1974 2002tii - gone
Polaris (aka "Mae West")
#2782824
1991 318is (aka) "O'Hara")
Brillantrot - High Visibility Daily Driver
BMW CCA #1974 (one of the 308)
deliawolfe@gmail.com
Delia
kudos to you Delia! :) Lol. When I bought my 76 02 last year i drove it over 6000km in 2 weeks. Needed nothing but a little oil.
No trailer needed.
8 weeks of Navy bootcamp taught me everything I need to know about space utilization. ALL that fits in two bags between the rear shock towers. There is still room for the cooler full of beer and clothes and such.
Steve J
& too many bikes
