Rear bench re-installation
Go to solution Solved by Son of Marty,
Hey, I was only able to find this misplaced article without solution, so I'm give it a try here.
" I cannot seem to get the rear bench seat to click into place. I am wondering if there is a tool or technique for this. I can almost do it myself but it may require 2 people. If I stand inside the cabin and push with my shins the clips come to within 1/2 - 3/4" from the back of the kick plate. "
That's my problem too.
Upholstered the bench and now it seems that something is blocking it rear center. I already reduced the cushion to a minimum there so the backrest (tightness) is not the problem. But I struggle to find out what it is.
Edited by 02sahara
You have to push really hard to engage the clips at the front edge of the rear seat cushion.  If you had the seat back re-stuffed and the shop was over-enthusiastic with the stuffing, it makes reinstallation even more difficult.
You could try bending the clips on the cushion just a little so they'll go over the riser a little easier, then once you have them in position, sit on the seat to pop the clips in place.
  • Solution
Push on the front bottom "rail" of the seat frame to get the clips back behind the sheet metal.
George S Patton
My new-to-me ‘73 (restored with new stuffing, too) arrived with the seat bottom unclipped and I’ve been wondering the same, @02sahara.  I’ve only fiddled, but from what I can tell, @Mike Self’s italics are well founded.  I’m gonna need to get in there in use all my “huggability” to pop it.  Better to do that one side at a time, or from the center?
John
1973 Nevada 2002 - 2023 CCA Classic Car Raffle car
Other - 2022 V60CC, 2014 B8.5 S4, 2003 TJ
Past - 1996 318ti, 1999 323i, 2004 X3 (with 6-spd manual), 2007 328i (spt pkg), 2015 XC70, and a whole mess of GTIs in the old days.
@JKKH I would try from center, but that's because I do have a square tail-lights '76 one that has a center metal thing where a screw will secure it. As far as I've read, the earlier models don't have that, so might be up to you.
I'm gonna get some help this weekend and hope for the best to get it back in as I finally finished the upholstery and partly new seat cover (only renewed the ripped fabrics with Alcantara) and kept the vinyl on the sides. (I don't wanna go through that process again, I can tell you.)
Let me know how it goes!
John
  • 5 months later...
Reviving this for future searches.  In my 73, I have the inertia rear belts, which were installed close to horizontal (pointing at the outer hip of the front passengers.  Try as I might, couldn't get the bench bottom to clip in.  I ended up loosening the outside (the male inertia belt) belts, pulling the the bottom corner of the seat back out and tucking the rear portion of the plastic inertia cover back up under there so they are pointing up towards the top fronts of the pop-out side windows (a bit above 45 degrees) and tightening them down.  That allowed the rear bench bottom to 'get on in there' and pop in place.  It still took some cranking, but with the belts "down", they wouldn't go at all.  Hope this helps a new '02er down the line!
John
