Removing Old Adhesive from Aluminum - Grills
gruizer
I'm on the long journey of re-assembling my freshly painted 02.  Part of that is trying to refurbish as much of the original trim as possible.  I've found many posts here about freshening up anodized aluminum.  I really like the look of the early grills without the black slats, so I removed the slats and now I'm left with glue residue from 50 years ago.  I'm having a heck of a time removing it from the grills.  How do you guys get your grills to look so good without the slats?  Here is a pic of what I want vs what I have right now.
1 minute ago, conkitchen said:
whilst I'm a bit of a maniac when it comes to let's see what works, WD40 and a mild steal wool does wonders.
see my tag line below
The steel wool and wd40 has been working to make it shine, but that glue is really on there. I’m thinking I might have to soak it overnight in thinner.
The factory, I think used something akin to contact cement (AKA gorilla snot); I had no problem removing the old glue on my '73s grille slats by soaking a paper towel with lacquer thinner and wrapping it around the offending slat.
I also had good success with a gently applied heat gun to remove the old slats; when heated, the slats take most of the glue with 'em when you pull 'em loose.
I wouldn't use steel wool, though.  You'll dull the anodizing.  How about some crumpled up aluminum foil?
