tii valve cover R & R — stuck in the middle
schuetz1619
Go to solution Solved by Son of Marty,
Valve adjustment done. Now how do you get the valve cover back on? I got it off with considerable contortions but can't reverse engineer them.
You can't simply put the cover back on as you would on a carbureted 2002 because the plenum is in the way of the cover's breather tube. I checked the Blue Book for asistance and found that it ignores the tii and its unique space issue. Unless I'm missing something, you need to remove two or all three upper studs, remount the cover, and then replace the studs with cover in place.
You could, of course, remove the entire injection linkage and then the complete intake assembly and  . . . never mind.
Am I missing something, or do you pull the studs?
Many thanks
  • Solution
Your problem is your trying to fit a standard m10 valve cover on to a tii. This is a 320i valve cover but the tii one shares the same breather outlet.
inv_022101__68260.1550546648.jpg?c=2
Edited by Son of Marty
George S Patton
