Quick Sneak Peak
bergie33
Non-functional 74 Tii Clock
PLUS
Volvo VDO clock
EQUALS
A working 74 Tii clock with quartz movement and factory face and hands.
That's all I got for now. More details and probably a tech article to come later.
Edited by bergie33
  • Like 12
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
Looking forward to learning how you managed to remove the crimped-on bezel without damaging it or the case...
PS.   the mechanical 72-73 tii clocks--and the 1600 clocks that substituted for tachs--are usually pretty easily repaired.  The problem is usually the points that control the solenoid that winds the clock spring--they're burned and don't transmit current, same as a bad relay.
Removing the bezel isn't too difficult, but doing it cleanly is nearly impossible.  Luckily the 1974 shroud for the clock hides the imperfections.
My last '02 was a '73 tii.  Back in about 2003 I wrote what I think was the first how-to on repairing the earlier clocks, and had it posted to my GeoCities site.  Its too bad the '74 clocks are not repairable.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
  • 3 weeks later...
Finally done with my Volvo clock conversion. Unnoticeable from the outside. The ground is a little different in the VDO clocks, so I had to solder a ground wire that I could attach to the case. Turned out great. I'll do a full write up in my blog in the coming weeks.
Edited by bergie33
  • Like 4
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
