Talk me off the ledge ****INSTALLED****
conkitchen
9 minutes ago, conkitchen said:
It's for when the Cop asks "do you know how fast you were going"
That actually happened to me. I ended up with a ticket for defective equipment. 😁
Which I got out of when I showed the judge my correspondence with North Hollywood Speedometer.
Ray
2 hours ago, conkitchen said:
So there I was, staring into abyss of stuff I have laying around. I found a vintage roundel. You know the ones with the clear rubber coating. Perfect.
Had to hook up a ground wire for the horn button and did a slight refinishing of the aloomineeum horn cover ring. The China finish was a wee bit stupid so I chucked it up in the lathe and spun sanded/polished it.
Have to say, I like it except the wood wheel is really smooth and hard.
but what do I know-(how many is that now Ryan?)
That looks amazing. Is it compatible with a Momo adapter or did it come with its own?
2003 e39 M5 (daily)
1986 e30 325es (sons car)
I had an adaptor laying around which had no markings. All I had to do really was the following.
1) Machined off the concentric ring of the hub.
2) Re-drilled and tapped new bolt holes and pattern for this wheel.
3) Added a ground wire for the horn button
4) Re-used the horn contact from the stock wheel
5) lil custom touches like the roundel and horn ring spun finish.
but what I know
But what do I know
but what do I know
Fixed that last line for you
Edited by danco_
some cars
some motorcycles
some airplanes
some surfboards
