Steel wheel rim width (15cm or 16cm)
cvvick
Go to solution Solved by Conserv,
Can you show us the markings on your rims as well as overall photos?
The nominal 4 1/2” rim has an overall width of approximately 5 1/2” (140 mm.). The nominal 5” rim has an overall width of approximately 6” (152 mm.).
Both sizes were used on ‘02’s, although the various related to both sub-model and year. All tii’s, however, came with nominal 5” rims — meaning approximately 6” overall. I suspect you have one tii rim and three non-tii rims.
The green one is stamped 11 78 for November 1978 making it an e21 wheel. It's also stamped 5 1/2x13H2 which makes it a 5.5" wide and 13" diameter.
The black one is stamped 10 75 for October 1975 making it a 2002 wheel. It's also stamped 5.0x13H2 which makes it a 5.0" wide and 13" diameter.
  • Solution
+1
So those are the styled-steel rims introduced with the square taillight ‘02’s and continued into the e21 era. They first appeared in September 1973. The rims accepted small center caps.
Here’s an entry from this forum’s Wheels Database.
A 1972 tii had an earlier style of rim that accepted a full wheel cover. Here’s an entry from this forum’s Wheels Database:
