Poor Braking - Help Required
jwill214
Alrighty. So I removed the drums and shoes and used C clamps to hold the pistons in the bore while I pressed the brake pedal. The pedal is hard as a rock so no air in the lines. The cylinders also do not leak anywhere so I'm convinced I have the wrong shoes now. I took some pictures for people to check out. I can't find a part number anywhere on the shoes. What do you all think? See anything obvious?
I measured both just to make sure and they are the same length.
I fixed, or bandaided, the problem by welding onto the tabs. I gradually built up material and then ground it down so that the shape matched what I originally had. I lengthened them by about 5mm on each side. They could probably be a little longer as the pedal still travels more than what I think it should but at least it isn't hitting the fire wall.
If I recall correctly those drum shoes are Enduro brand. I remember ordering the same shoes and there was not label on the box whatsoever with exception said made in China. I told myself no Chinese brakes on a German car so I return them and opted to go with genuine parts($$$$). I am sure many of us have Enduro shoes on our cars and they are working just fine, but the issue here is quality controls from batch to batch.
76 2002 Sienabraun
2015 BMW F10
I ordered all my brake stuff with the exception of the flex lines for two cars from Blunt. Pads and wheel cylinders are ATE.  Shoes are one of the two major brands he offers (Jurid).  Zero issues.
Edited by jgerock
^ That.
Ordering from someone who knows and drives these cars will get  you parts that are proven to work.
And perhaps ice cream. Or coffee.
:D
Ray
2 minutes ago, ray_ said:
^ That.
:D
And maybe a new nickname on your shipping label.
I bought a rebuilt brake booster, branded by Centric... it was in no way a 2002 part. It "kinda" looked like it would fit, but I sent it back.
Hope your brake troubles are behind you now.
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
