Is it necessary to run the cooling system through a downdraft intake?
I’m considering switching from a sidedraft setup back to a 38/38 using a stock intake. Since I’ve already done the work to bypass the intake cooling, will I run into problems if I just throw the stock intake on there without going through the motions of reverting my cooling system? If so, why doesn’t a sidedraft require cooling?
Thanks for the insight!
-Ryan
In warmer clients not necessary. The coolant through the intake is there to heat the intake not to cool it. Heated intake helps the air fuel mixture in cold climates
"and drier climates".  Humid climates are another story.
i drove my 2002 all winter 2 winters ago with no chokes and no coolant running through the intake.  once its gets some temperature in it, it runs and idles fine.  coldest day i started it was 10 degrees F.  battery needed a jump but other than that it started up and held a idle after about 3 mins of hold constant rpm to get some temperature in it
I wonder if it also just helps emissions too, as in warming up the fuel/air mix for more complete combustion.
(...pitch it)
Bring a Welder
(...pitch it)
Picture an old Indian (they say Native American nowadays) standing on the side of the road with a tear in his eye.
But what do I know
Quote
In warmer clients
Yeah, don't try to stick coolant hoses into your cooler clients...
Contrary to whatit might seem, it helps with fuel/air mixing.
Without it, fuel condenses in the intake, and doesn't get burned.
I run it.  Even on track cars.
