Fuel Injection Bobbing
14 hours ago, buckweber said:
Problem is back.  Per video car runs sting at higher rpm.  It has a wicked miss at 1800 rpm.   Car stalls coming to a stop
cleanened the banjo input filter and return on Kugelfisher.    Only thing I have been working on is alternator
any ideas?
IMG_0110.MOV
Did you manage to upset the throttle linkage while futzing about down there?
rtheriaque wrote:
The injection manual has a procedure to test each injection path.  While the engine is running,  cracking the nut on top of each delivery valve should effect  the performance  of the cylinder.  If it does not  there is a problem with the suction valve,  delivery valve or injector.
73 Inka Tii #2762958
i can't get one of the injectors apart. Can it be heated with a torch or will it get damaged.
Don't know.  I'd put it back in the engine and run it.  Do test procedure to find the fault, if any.  Add fuel injection cleaner to a 1/2 tank of gas.  That will clean the injectors etc.
Once CE back together I will test per procedure in Kugel manual
You are about 7 hours from me. Send me your injectors and I will clean them. Only thing you have to lose is shipping and time. Pm me.
1 hour ago, buckweber said:
Thanks Paul. I got it apart today and soaking it on carb cleaner. If this doesn't work I will take you up on your offer
Haha.  That's Jim you want to thank for the offer.  You wouldn't want to send them to me as I'm in Canada, and I'd send them out to be electro-statically cleaned and burst-tested as that's the kind of obsessive person I am.:wacko:
Edited by PaulTWinterton
I messed up and removed all of the fuel lines at the same time.  Don't remember how they map.
Is it.
Front Drivers side= Cylinder 1
Front Passenger= Cylinder 2
Rear Driver=Cylinder 3
Rear Passenger=Cylinder 4
How do I confirm?
Put it all back together and ran good for an hour.    Now trouble stating and sluggish
i would think sludge or something from tank.  Had it dipped at radiator shop and plumbed all new from tank to kugel.
Also so after heats up it is smoking from either under distributor or exhaust manifold.  Need to figure that one out
high note.  Registers it for first time in 15 years and had it on road.!!!!
