MSD proper plug wires
Dudeland
From MSDs technical manual.
I am running 7mm heli-core wires from NGK. Obviously MSD offer their own. I am thinking of getting the Ireland Engineering set next time.
rtheriaque wrote:
Possibly over thinking this. I've used a slew of wires over the last 15 years on the same ignition system: MSD6a, Pertronix, red coil, NGK  BP6ES. Currently using a set from Kingsbourne
i am dealing with some childhood anxiety after trying to put a set of plug wires in an old boat my dad had. Cutting them to length and terminating them still produces a nervous twitch.
After looking into "make your own" sets it seems less intimidating.   I think I will go with a MSD set, since they all seem to be about the same price point.
"Goosed" 1975 BMW 2002
I've used the Accel do-it-yourself 8mm kits for AMC V8's- you get enough parts for 2 sets, minus the distributor wire...
$60ish now, I suspect.
