VIN Plate
Driv3r
The originals were stamped, but virtually all the re-done tags I've seen have been etched or engraved.  In order to stamp it, I'd guess you need a set of number stamps in precisely the correct font and size as the originals -- something no one appears to have.
I believe that La Jolla Independent BMW sells the VIN tags as well, and might have a source for completing them.
Edited by Conserv
i was looking in to the same thing... I plan on making a vinyl sticker (of the black portion) and stick it over my original, cutting out a window for the stamped VIN number. I'll need to clean up my original vin plaque too.
I could share it with you, if you like.
Edited by MildSeven
picked up what i thought was a sound Verona Red '76
The Refresh Blog: http://www.bmw2002faq.com/blog/155-76-verona-red-refresh/
Thanks Champ. I'm after a stock look. Although we can't touch vin plate in Australia, we have to prove its completely damage then order a new one through authorised mechanic.
When I redid my engine bay I bought all new stickers and a new VIN tag from La Jolla.  I then bought this 5mm number punch set off Amazon for $15 and carefully stamped it myself.  I DID also keep the original for authenticity's sake. . .
https://www.amazon.com/gp/product/B001AKHURK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Maybe 4mm set would've been more accurate?
Yeah, 5mm was a tad big, but I don't think I found a 4mm set, just 3mm, and that would've been way to small.  Oh well, I'm still pretty happy with how it all turned out!
So I looked up the metal punchers online and can't find one close to the oem punch. The oem vin punch is like a razor cut font.
So considering you're in Europe, is your oem vin plate font is same as mine?
Yes, I wasn't sure if they were made in same font style from 66-76. I need to source somethings closer to this font so it would look closer to oem rather than an obvious copy even thought the original plate is retained. Cheers
And besides finding the weights both printed in black ink and showing the appropriate weights -- there were several different weights, largely dependent on year, e.g., round taillight vs. square taillight -- the closest VIN repro plates I've seen show "2002 tii" rather than the "2002TII" printed on my original VIN plate.  So if you want to get a replacement VIN plate "just perfect", you've got an uphill battle.
And, oh, yes, the original VIN numbers were generally not dead straight, perfectly centered in the box, and evenly stamped: more often the numbers' heights and stamping depths differed slightly...
Best regards,
Edited by Conserv
