Need help with price
jdawgthethird
I need to sell a project car and am soliciting your help in determining a price.
1969 2002, no motor or transmission
Its in somewhat rough shape, and will require rockers, outer arches, and a drivers side frame rail.  There are pinholes in the spare tire well and will probably need a floor patch on the drivers side.  Otherwise the body is straight - no visible signs of being bumped.  It's in primer grey and it rolls.  It appears someone rattle-canned silver and clear - both of which are peeling off.  It's been garaged since I've owned it (2 years).
The rear shock towers are good.
The nose is good, needing just a small patch near the lower lip.
The grills are there, with one vent fin needing to be reattached.  The round taillights are painted, but in decent condition
This is a west coast car for most of its life.  I bought it from a guy in Utah that bought it from California.  The car is now located near Washington DC.
I've been collecting parts for 2 years for it:
m42 motor from a 1991 318is and the matching 5 speed.  Good compression on all 4.  Includes ECU, harness, driveshaft
3.91 lsd
Recaro fronts, needing re-upholstered
Rear seats from an e24 6 series, black, no blemishes
a/c unit and center console
replacement windshield
belt trim
What's a ballpark figure for selling?  I'll add photos tomorrow.
Edited by jdawgthethird
added photos
A 1969 BMW 2002, no motor, no trans in somewhat rough shape should fetch $500 to $1500 depending on the location.  The other parts have some value, the M42 motor and 5 speed, LSD, Recaro seats, E-24 rear seats, belt-line trim should fall somewhere between $2000 - $3000.  So ask for $5K and be happy with anything over $3,000, or just take a lot of pictures, load it up on eBay at no reserve and see what the market thinks.
IMHO,
Mark92131
1970 BMW 1600 (Nevada)
What's the VIN?  If it's below 1664760 it's a "first series" '69 with a long-neck diff, two speed heater fan, separate clutch hydraulic fluid reservoir etc. They were produced before 1 January 1969 What that translates to is needing a late style rear crossmember and drive shaft to use that 3.91 diff.
