is this instrument panel spade terminal for the low fuel/brake light
ray_
7 hours ago, Conserv said:
Ray,
Yes, the wire that hooks up to the spade terminal comes from the emergency brake switch.  The spade terminal only appears on some 1974-manufactured clusters (well, square taillights, but pre 11/74, at least), so later cars must have received a more "built-in" wiring solution:
The above thread seemed much more exciting when we originally wrote it: the plot's a bit thin in retrospect....
Thanks Steve, I missed that one in my search. I think that clarifies the issue. Mostly!
Ray
And you know me, Ray: I'm always happy to provide vaguely-ambiguous assistance..... ??
Best regards,
Is there a provision on the USA tii fuel sensor/sender & instrument cluster to add the needed wiring and get the low-fuel function?  That's a feature I'd like to have (no matter how inaccurate!).
John in VA
  • 2 years later...
You would need to swap out the sender. The warning light works by a copper strip on the float bridging out two contacts when right at the bottom of its travel. You could probably fab up something similar yourself if you are handy.
On 8/5/2016 at 9:13 AM, ray_ said:
Don't worry; all we need to be is less un-electable than Trump.
It's a cinch!
:D
Damn it Ray, this didn't age well.
  • Haha 1
Bring a Welder
