Rocker Trim Adhesive (Recommendation Needed)
2002#3
'02 Friends,
Can you recommend an appropriate adhesive to attach the grey rubber strip/seals (see attached photo) to the stainless steel rocker trim which runs along the lower edge of the body?  Yes, I know they are dirty.
Thanks.
Larry
Follow the 3M instructions and start with surgically clean surfaces. I cleaned mine with lacquer thinner, beforehand. Apply adhesive to both pieces…allow to set up for 10-15 minutes….THEN stick them together.
Paul Wegweiser
Just a question in relation to this, my 02 did not come with any rocker trim, are the grey rubber strips a seperate part that that needs to be ordered with the metal trim, or do they come together? I know I need clips also. Thanks!
1969 2002 Granada, 2nd owner
1976 2002 Fjordblau (owned 10 years)
A few steering wheels
  • Administrators
Rubber pieces are separate from the aluminum trip.  Just replaced mine. There are three of them per side with different part number.  Left and right are the same, but there is a front (shortest), middle (longest) and rear pieces.  Front and rear are same stile but different length, the middle one is completely different.
steve .
