Found inside door, what is it?
peterschop
Go to solution Solved by John_in_VA,
I just took my drivers side door card off and found a couple of pieces of cast iron about 4 1/4" by 3/4" by 1/4" in the bottom of the door. One piece is kind of wedged under the window channel but I could probably get it out. They look like they could have been one piece that has broken in two. Is this something that should be in the door? It sure doesn't look like it. Could this be something to support the window channel?
post-41415-0-89858800-1427254200_thumb.jpost-41415-0-70669700-1427254218_thumb.jpost-41415-0-05306000-1427254238_thumb.j
I also came across an interesting mark on the door, probably from the factory.
post-41415-0-76782400-1427254346_thumb.jpost-41415-0-78428100-1427254356_thumb.j
Door brake? It don't look like the one on the door now. It is thicker and nowhere for the pin to drop in.
Oh wait, I think I see it now. Those two pieces must have once been together and were the outside part of the brake inside the door. That must be why my door will not stay open by itself.
Edited by peterschop
Part number for the newer style door brake is 51 21 0 301 601 (the old part #51 21 6 450 014 is NLA )
Get Blunt to send you one, or your favorite vendor -they are approx $90 each.
Beaner7102
