ash00
Thanks everyone for the feedback. I really appreciate it. What load option works well with dcoe carbs, TPS or MAP? Anybody have pictures of their setup?
Aashish
1969 BMW 2002--I gotta finish this damn thing
1987 BMW 325is--S52 Monster
1975 Innocenti Mini 1001-- the most cost dense car ever!
1995 318ti
2004 BMW 330i ZHP
2004 Toyota Tacoma (gotta have something reliable!)--can't live without
Yeah I think you'd have to drill ports in each of the runners and plumb into an accumulator. I was interested to see if that's the approach or if I'm thinking way out of the ball park
Aashish
1995 318ti
2004 BMW 330i ZHP
Ashish. I'm running MS for both fuel and spark, so my situation is a little different, and I'm also running ITB's. My original intention was to run solely on MAP, but then move to the more advanced mode of sort of blending MAP and AlphaN (TPS.) The way I run MAP was to put a little vacuum port into each of the four throttle bodies, then run these to a common tube that supplies a MAP signal to the ECU. By ganging the four like this, apparently the signal is steadier. After running with it like this for some time, and also doing some tuning work on a dyno, I honestly just decided not to pursue the idea of blending in TPS. My understanding is that TPS provides greater granularity at high rpms and WOT, but for "normal" drivability, MAP is actually better. If yours is for the race car, then this may not be the logical approach. In the photo attached you can see the tube I made as a vacuum collector (stainless tube just to this side of the valve cover with little black hoses feeding into it.) This is before I moved to an airbox, but the basic set-up remained the same.
Thanks Grover! Great looking setup.
Looks like there is a tachometer board for the megajolt as well. Guess I'll need that as well?
Aashish
1995 318ti
2004 BMW 330i ZHP
Aashish
1995 318ti
2004 BMW 330i ZHP
Hey guys
Looks like I got the bulk of the stuff on order.
Does anybody have the part number handy for that ford crank sensor?
Aashish
1995 318ti
2004 BMW 330i ZHP
