Capacitor On Coil?
Go to solution Solved by TobyB,
I recently took my new Bosch "black" coil off and put the old one back on. I had replaced it when I did my initial tune-up, after buying the car. I prefer the look of the old one and the fact that it says "made in Germany" on it. It seems to work just fine, so why not? The question I have is, what is this little capacitor for? Was it added to extend the life of the points?
(I ran a Pertronix for a bit, but am currently using points FWIW) Tom
Yes, it is bypassed during engine cranking to send full power to coil by a relay. Otherwise it will shorten the life of your points if it is removed. It should be 1.1 ohms. Never used it with a blue coil. If you replace your black coil with a red or silver one the label will say use a 1.8 ohm resistor otherwise the coil will overheat. This has happened to me.
HBChris
`73 3.0CS Chamonix, `69 2000 NK Atlantik
`70 2800 Polaris, `79 528i Chamonix
Thank you Toby, it seemed sort of randumb, but thought I would ask.
HBChris, my car has the resistance wire in place of the ballast resistor, which I bypassed to run the Pertronix unit.  Back on the old wire now and running points.  I am pretty sure this little lentil is unrelated, but thank you for your input.
