Engine runs for 15-20 sec after turn off with key out!
mtriple
The only thing that was replaced was the distributor. specs:
side drafts
85 amp alternator
electric ignition (it is the IE distributor brand new unit)
MSD ignition
Red Coil
What in the world could cause this??
TIA
hamada
70Bristol02 E36M3 E34535im
Your timing is waaaay out! When I brought mine home it was set at 10 deg at 2500rpm and "dieseled" for about 5 seconds. Scary
I cleaned the carb, nada, set the timing and fixed 1 vacuum leak, problem solved.
If it still does it, you will need the M20 repair :D
'72 2002
Lots of Brit and Euro Motorcycles
A couple of American Cars (dead in the yard)
..and a pile of magazines with the vehicles I want next
Are you running an electric fan? If so depending on how you have it wired it could be acting like a generator when you turn the key off and supply just enough power for 5 sec or so to keep the ign system working.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Interesting thing you say Byron, Great Scott!
So; if I have a big enough fan wired into my ignition system I could run the car without the HP drain of an alternator. Provided I go fast enough to keep the propeller spinning. Might even be the solution to perpetual motion.
Hmmm,
But what do I know
If it has an electric fan it can back feed the ignition & make the engine run on , I believe a resistor is needed on the ground side of the fan to prevent this happening.
So; if I have a big enough fan wired into my ignition system I could run the car without the HP drain of an alternator. Provided I go fast enough to keep the propeller spinning. Might even be the solution to purpetual motion.
Hmmm,
Yeah, just hook that fan up to an electric motor, get that car up to speed and just keep on goen.
Too many cars.
I believe it was timed correctly. It drives excellent, but the engine insists it wants to run after I take the key and walk out of the car. 20 seconds is a bit much.
No electric fan and I believe the diod was replaced by indie trying to troubleshoot. Also ignition switch was replaced thinking it was faulty.
I've been in WTF world for a few weeks now...
When was the last time you had the head off?
Could be that you have a load of carbon on your head / pistons / valves and that is glowing hot and giving its own ignition.
I think having your idle too high can exacerbate the issue since there is more stored energy in the flywheel.
That is it , a diode, it was late when i answered that , we have had a few cars come in with the same problem, diode did it :)
Check for voltage at the coil when you turn the key off. If there is power there you need to figure where it is coming from. If there is no power then you have a problem with carbon build up, idle speed, plug choice etc.
1974 2002 Turbo
1988 M5
1986 Euro 325iC
the year before last year when I had the proper valve guides installed is when the head came off. Idle was set at 900 when I test drove the car..
MSD ignitions, at least the older versions, came with a diode that was put into the line when you installed the MSD to prevent current leak back that made the engines run on after you shut off the ignition. My engine would run on forever without the diode so this is probably not your problem but it is an interesting quirk of the MSD system.
Have fun
