OIL FILTER SEAL POPPING / SPEWING OIL
classicman
HI
My 74tii is fresh fom a complete rebuild. When I first started the motor, the seal on the oil filter (new Fram PH4875) popped on the one side and the car spewed fresh oil all over my garage floor. I took it off and it all looked fine. I thought the seal maybe wasn't seated correctly the first time. so I carefully replaced the seal and filter.
All has been well until this morning when it popped the seal again, this time just up the road, so luckily I could freewheel the car back home. I took the filter off again, and everything looked fine. I have put it back on again to see how it seats, and it looks as though the filter fits slightly skew. The side facing the front of the car seats nice and flush, but the side facing the firewall looks as though it is about 1mm higher than the front side. This is where the seal is popping.
Faulty filter, wrong filter or something else to look for??
74tii - Alpina A4 Spec
71 3.0 csl - to be restored
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
this question usually arises at the first frost,
not warming spring season
that filter's "burst rating" is not high enough
for the peak cold pressures in a M10 motor
you have a stuck oil pressure relief valve in the oil
pump
you need to attach a oil pressure test gauge to
read the cold, hot, 4500rpm hot pressures to know
you reving a cold motor doesn't help either way
with a poor quality filter and the normally high
cold oil pressure 90 - 130 PSI!
get oil pressure readings
get a 'bmw' MANN type filter
'64 R27 250cc #383851 18,000m
Thanks c.d.iesel.
What should the pressures be? I'm looking to fabricate and install an Alpina style instrument pod on the dash using VDO gauges from a mk1 VW Rabbit GTi. Just want make sure that the increments on these gauges would be similar to the 02's.
NEW PUMP?
improperly installed? been there done that . Drop pan w/engine in car fix pressure relief (in upside down ) D.H. Drop / remove the pump
3421912 ask john
Red Baron a 74 sedanw/ dual webers ,spring,steins,bars. body shop for a full make over
Red Baroness a 71 1600 touring new to me and on the street in Limburg
Old Reliable a 93 318 m42's are soooo cool
Ya shouldnt be dropping that seal on a Fram, I've run one for darn near 3500 miles and never had an issue. It's not the best filter out their either but thats not the case at hand. Check your oil pressure release. like mentioned above
-Nathan
If like you said this is a fresh engine and it popped the filter seal first time you started it the oil pressure relief valve was assembled incorrectly. You will have to remove the pan to correct it. I am sure the vent tube was installed upside down. For some reason there has been a lot of that reciently.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
^^this^^
Byron's right- if it did it from day 1, it's a relief problem. If it starts
after 5-10 years, it's a binding problem.
A gauge is a good idea- if it's stuck, it'll shoot through the roof when your
oil temperatures are low. It's not a problem with your filter, it's the pump relief valve.
back in the day, i worked at a company in dallas, dallas european parts distributors. we sold a lot of febi oil pumps. the only difference from the febi and genuine was the genuine had the extra oil pressure relief spring in the pickup. the febi oil pumps came in a plastic bag, and since there is nothing to hold the oil pressure relief valve piston and spring in the pump, they would always fall out, and be loose in the bag. we had dozens of these exact complaints, and every one was because the relief valve piston was installed upside down. i am also sure the piston is in there upside down
Ken Inn
classicman -
you'll need a oil 0-150 oil pressure gauge
and correct sender to match
cold idle - 60+psi
cold 3,000 rpm - in excess of 90psi
hot idle - 18 .... 30 psi
hot 4,000 rpm - 48-60...75 psi depending on condition of motor
and if your building a 'Alpina' 3 ,4, or 5 gauge pod,
think about an outside temp gauge.
Warns you of black ice and freezing temps.
Keeps you out of the hedge rows on cold morning romps.
BMW instrument clusters have been chimming for decades now
on cold start-ups warning drivers that the road is frozen and tires are
hard!
Classicman resides on the Eastern coast of South Africa. And it doesn't get close to freezing temps there(think south Florida). It rarely gets below 50'F. Gotta love our weather...
I also second the relief valve problem. It is easy to get wrong if you are in a hurry.
Regards
Jacques
'71 2002 Malaga, fun weekender
'70 2002ti Colorado, Restoration/money pit
'74 2002 turbo in my dreams, sideways...
port elizabeth south africa, port elizabeth new jersey usa
sorry - guess i had a 50/50 chance of his location
Lol, I see your what you mean. Never knew there was a Port Elizabeth in Jersey. Every day I lean more... But I would say since this is the FAQ, the odds would be in Jersey's favor. 60/40 ?
Regards
Jacques
lol, I didn't know there was a Port Elizabeth in the USA - weird!
Jacques, you following me around, I'm starting to get nervous :-)
Thanks for the advice guys. I'm thinking (hoping) that the problem is high oil pressure and cold oil. It has happened to me twice, but I have run the car quite a bit inbetween. Both times it happened at startup when the car was cold.
I'm going to try a better quality filter to start with and fit the guages so I can see where I'm going before I drop the sump etc.
IF you are very carefull on start up and keep the revs below 1500 or so and wait until it warms up you can get away with the relief valve being stuck closed but you are putting a HUGE load on the oil pump and chain. This pump is capable of making 300+ psi when it is cold. Just having the oil filter NOT blow is not fixing the problem ( kind of like taking enough asprin so your broken leg does not hurt any more and thinking you have fixed it) Sooner or later you will strip the splines off the oil pump and it just won't turn any more, fix it now and correctly and all it will cost you is a few hours and a oil pan gasket.
1974 2002 Turbo
1988 M5
1986 Euro 325iC
..."Never knew there was a Port Elizabeth in Jersey.
be in Jersey's favor. 60/40 ? "
BMW'S have always been 50 / 50 weight balanced
