S14/E30 M3 Instrument Cluster Swap...How does it fit?
Based upon the parts that are available to me at this moment, I have concluded that the only thing preventing my from swapping the M3 instrument cluster along with my S14 is an aesthetic reservation. Cost is equivalent, unless I am missing something....(used to it by now).
How do those gauges fit in a 2002 dash? Does it require cutting up the dash? Anybody have a picture of a completed cluster swap?
Could I go back to stock 2002 gauges without replacing the dash?
At this point, there parts are available to go either way......I just like the look and feel of those old gauges, but I know that a bouncy 2002 tach is not something I want at the track.
What would you do?
Machs Gut.
North Hollywood Speedo is redoing my cluster for my M2 swap. I acutally had a Turbo cluster that I had purchased a number of years ago that is going into this car. North Hollywood is also dampening the tach to limit the bounce. I am using a Getrag 265 CR box that we added the mechanical speedo parts to make it work with the existing setup.
<p>69 (M2 Project-stalled); 72tii (a) Taiga/ m42 swap in process;91 E30 vert; 2013 Porsche Cayenne GTS; 65 Mustang fastback 500hp+ resto mod in process ;72 Porsche 911s project; 70 2002 M2 2.5L getting closer
what is this "tach bounce" y'all are speaking of? i must be missing out...my stock 2002 tach works perfectly directly connected to the normal s14 ecu tach output. zero issues. well, one issue...it keeps trying to spin past 7k rpm every time i drive the car! :-)
2xM3
Weird, that's the only issue my tach has too. I had the problem explained to me by a technical guru - when the s14 passes 6k your shit eating grin becomes directly connected to your right foot, and only the intervention of the rev limiter can break the connection. No bounce though
That is why I took it up to 9K on my cluster redo.
an expensive fix!
an expensive fix!
yes..but not as bad as if I had to pay in euro's
I am a little confused, I have the 5 spd. transmision, but with the S14 swap my speedo is about 12 miles per hr. off. (reads faster than actual) I am also running 15 inch wheels. what am I doing wrong?
72- Tii M2
87- Porsche 911 Turbo
01- Mercedes CLK Cabrio
07-Touareg V8
91- NSX
08- VW GTI
I've also never had the bouncy tach issues either
You can send you Speedometer to North Hollywood Speedo and have them recalibrate it. I lived with it for years until I found a one that had the correct recalibration already.
Ray
73 Chamonix-S14 powered
Elefant Supply Apparel & more O=00=O
faq sig
