Great performance at high rpm, low rpms not so good
asifallasleep
74 2002, 32/36 Weber (recently calibrated), new Pertronix ignition, new plugs, new 8mm wires, new coil, new fuel filter, new air filter plugs gapped at 24.
If I go to 3rd gear before car gets to 3000 rpms, car seems to misfire/hesitate as if gear is to high for low speed. Even at idle there's the occasional hesitation. If i drive aggressively, as in not going into 3rd gear until i'm at 3000 rpms car runs fine. Highway speeds car is great.
Perplexed. Almost as if it's tuned for higher speeds. I know spark plug gap can effect this. But for what Im describing wouldn't it point to a large gap? Any ideas?
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2000 Porsche Boxster
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
at what stage of all yer parts swapping DID THIS BEGIN TO HAPPEN ?
retrace yer steps to happier- smooth running
try to pinpoint at what throttle opening does it
act worse?
at o - 1/4 throttle opening ?
at 1/4 to 1/2 throttle opening ?
at 3/4 to WIDEOPEN throttle ?
((it's assumed your compression readings, valve adjustment,
and ignition timing are "correct"))
'64 R27 250cc #383851 18,000m
Mannn I just went thru this same scenario. So mechanic runs compression test. real low on all 4. in fact I had 70-90-110-80 or something like that. Yank valve cover. ALL valves too tight. I guess as the seats wear in the valves come up higher. Has the car been harder to start? Almost wanting to flood at times? Run a compression test. Its easy and cheap. i learned my lesson. Once he adjusted the valves back to normal car hauls ass
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
Compression test was done when pertronix was installed and was fine.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
going to increase idle speed a hair and make carb 1/2 turn richer. may also gap plugs to 30. currently at 24 with pertronix installed. i keep thinking engine is not getting enough fuel at low speeds with higher gear. if gas pedal is halfway pressed or more, no hesitation at all.
i've always had 5 speeds or 6 speeds. perhaps i'm shifting too soon? i'm already in 3rd pre 3K rpms. if i leave in 2nd until 3K rpms and beyond, car rolls like a rocket. real spirited driving. but don't want to drive like that all the time.
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
big improvement. upped the plug gap to 28 and 1/4 turn richer on weber and she hums now. hopefully the missing won't come back.
thanks everyone
PREVIOUS:
1979 Jeep Cherokee
1980 VW Scirocco
1983 Porsche 944
1986 BMW 325i
1999 VW GTI VR6
2000 BMW 323
2001 BMW X5
2003 Porsche 911
2003 Mini Cooper S
2005 BMW Z4
1974 BMW 2002
Current:
1995 BMW M3
2003 Infiniti FX35
