New M3 starter Upgrade
Tiger75
I finished installation last week, but did not get to drive it till this past weekend. The starter really turns the engine to a high cranking speed quickly. Engine starts up almost immediately. I have a Tii and you know how you have to let the electric fuel pump pressure before you crank. Well, mine starts up immediately with out doing that. I will have to let it sit for a week or so and see if it still starts so quickly with out pressuring up the fuel system.
This is a great upgrade.
I highly recommend it!!
E30 body style M3 (the 4 cylinder ones 88-91 era). The main benefit is that it's far smaller and much lighter than the 2002 unit. Will not fit the reinforcing brkt attached to the front of the original one though - but may not need it - since it ways so much less!
makes engine work easier, too!
paul
read this for the wiring problem I had
http://www.thetiiregister.com/phpmyfaq/index.php?action=artikel&cat=19&id=25&artlang=en
I searched FAQ and that other board for all posts on M3 starters. Found a bunch, Best one was
http://home.woh.rr.com/fairacres/Karl/Karl.html
It is a step by step with pictures.
If I did it again I would use allen head bolts as shown at the end of this post
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,282795/highlight,tii+starter+removal/
I believe that an E21 bracket can be adapted to work - Some say it's not needed and some do. There's a lot of vibration down there and it never hurts to have something with that amount of weight/leverage braced at both ends.
E36
I found a used one in Houston for $75 but by the time I would have paid shipping and a rebuild shop , it would cost more than a new one.
I paid $135 for a new one + $55 core charge - really a bosch rebuild, don't think there are any new ones any more.
  • 6 years later...
Buy one of these and you will have a bracket. 12411308480
