I need mirrors ASAP !! help in LA.
bmw1602.com
just the normal ones. I need to bolt them on so I can rivit in my alum. door panels.
No, you don't. The mirrors don't require any access from the back of the door to install. There's a nut with ears on it that grab the back of the door which the mounting bracket bolts to.
Yeah, they 'just' install from the outside - if your doors had mirrors already on the right and left, and your existing 'door inside' hardware is good. Since most 02s don't have a right door mirror, that install typically does require inside the door access and drilling...
Where we goin’? … I’ll drive…
Or you can use a rivet nut aka riv-nut aka nutsert aka pop-nut like this:
http://www.hrpworld.com/index.cfm?form_prod_id=815,363_4353&action=product
Should be as strong or better than the factory blind nut jobbies and no need for fancy fine filing to make the slots. Once you own a setting tool (cheap these days at Harbor Freight and the like), you will find many more uses for riv-nuts, I guarantee it.
regards,
Zenon
'73 2002 Verona (Megasquirt/318i EFI conversion, daily driver)
http://www.zeebuck.com
res my right door (pass.) does not have any holes... so I will have to drill etc...
68' 1602
98' ///M3 Sedan
88' ///M3 Sold *
06' ///M3 Competition Pkg Sold *
http://www.bmw1602.com/
