Working on another 02 mystery: On-street parking lights
Weird stuff.
My May 69 6 fuse car does NOT have this feature. Left and right sides fused separately (1 & 3).
My May 73 12 fuse car DOES have this feature. Left and right sides fused separately (1 & 2).
Hi Jim
I don't think any of the US spec 69s had fuse wiring that would accommodate the on-street parking feature.  Mine (and yours) are fused thusly:
Fuse 1:  Left and Right parking lights
Fuse 2:  Right tail light and license plate light
Fuse 3:  Left fail light and instrument cluster lights
For the feature to work properly the wiring would have to be thus:
Fuse 1: Left parking and tail light
Fuse 2: Right parking and tail light
Fuse 3: license plate light and instrument lights
I believe Dave Hoovler is telling us that his early 71 (a 166/7XXXX VIN, not a modell 71 VIN (257XXXX) is wired properly and the feature works on his car.
So what we haven't determined is when in the 166/7XXXX VIN run were the fuses switched around and the car wired for the feature--as it requires additional wiring from the light switch to the turn signal lever, and another wire from the ignition switch to the turn signal lever.
It appears that all the 257/8/9XXXX VIN cars have a functioning on-street parking light setup.
We'll get to the bottom of this...eventually!
2 hours ago, Mike Self said:
Hi Jim
Here’s my (I believe original) fuse sticker from the 69.
Hi Jim
Interesting...your car was assembled four months after mine and those first three fuses are arranged differently from those on my car.  Wonder when they made the change in the fuse setup...
So it appears that the fuses on your car are arranged so that the on-street parking light feature would work, but since it doesn't on your car, it's lacking the two light switch-to-turn signal lever wires, and the single ignition switch-to-turn signal switch wire.
It gets more interesting by the day...
5 hours ago, Mike Self said:
Hi Jim
I did replace the original broken TS stalk, but all the wiring was identical.  Front turn signals are replacements that I added a running light connected to the original wire leads.  Steering column lock/ignition switch was also replaced with a new assembly. Light switch and Emergency flasher switch quite possibly original.
