hub / bearing / rotor assembly order
You need to be sure to keep the races square to the hub installing or removing then just a bit out and they freeze up, I take the old races and grind a few thou's off the outside and use them upside down to install the new races.
  • Like 3
George S Patton
Work your way around the race while installing or removing.  If the race gets cocked in the hub, it stops moving.
Yep, exactly what I did, and I'm sure I picked that up from someone off of this site (not my idea, it worked well).  Keeping them square to the hub is key (duh).
16 minutes ago, Son of Marty said:
Yes you can, but almost all wheel bearings come with races so why not use them?
Well if they are incredibly stubborn I may save myself a weekend full of creative blowtorching and hammering! :)
11 hours ago, Santawillis said:
If the races look okay, can you replace just the bearings as preventative maintenance and keep the old races?
Not if you want life out of the new parts.  A bearing consists of the inner race, the outer race, the rollers, and cage.  These make up the bearing.  Once a bearing used (run in), replacing only some parts ends up with accelerated wear in either the old or new pieces, take your chances.
It takes a stout drift punch and a 3 lb hammer and 10 minutes time.
Use a steel punch to knock them out a brass punch is to soft and doesn't provide the shock power that a steel one does.
Edited by Son of Marty
George S Patton
