Head bolts
Mikesmalaga72
Go to solution Solved by Son of Marty,
Before installing a fresh head looking for a lil advice on head bolt sealer near water jacket area and where that is. I remember trying to get a head bolt through a head bolt hole that had a real hocker of thread sealer on it out of a Tii 121 head once and it was a biatch. It had some really thick thread sealer on it and I forgot which bolt had the water jacket and which might have needed it if any. Any hints thanks!
  • Solution
Right none of the head bolts go into the water jacket unless you have a crack in your block.
Edited by Son of Marty
George S Patton
Oil, however, comes up around one of the front bolts...
...and most of them are open to cam oil.
So I tend to seal the top of the rear one that's exposed.
I HAVE had a water passage corrode through into a bolt tower...
Edited by TobyB
