Black Ignition Coil
healeyman
Go to solution Solved by John76,
So I may be the last person here to learn recently that Bosch ignition coils are backordered since forever with no delivery dates yet in sight. I'm  in need of a new or near new black coil (Bosch 00010) for my '76.
What are people doing currently with respect to replacements/substitutes?
Thanks.
1973 Ruby Red 2002 tii "Celeste"
1976 Fjord 2002 "Hazel"
New Bosch coils do not have a great reputation.
A lot of Porsche guys run 30-40 year old coils and carry a spare equally old coil. A good “old” Bosch coil is very reliable.
MSD high vibration blaster coils work well if they fit your application.
  • Like 4
I finally "caved-in" and replaced the stock points and coil on my '76 with a PerTronix ignition module and coil.
PerTronix Ignitor II (p/n: 91847V) with a 0.6-ohm Flame-Thrower II Coil (p/n: 45011).
You bypass (or remove) the resistor wire.
I try to keep my car tuned as best I can with the stock components (original owner), but after making the change to the ignition, I noticed a big improvement in starting, idling and cruising. Better fuel mileage too!
I'll never go back!!!
John
  • Like 4
Very helpful responses from everyone, thanks.
My take away is rather than waiting for Bosch coils to be available once again, perhaps I should seek out an aftermarket coil suitable for my application, including possibly a PerTronix unit, since I am already running a PerTronix Igniter II as John suggests, along with a black Bosch coil that looks like it might be original to the car.
Thanks all for your replies.
Matt
  • Solution
Matt,
The original black Bosch coil is 1.9 ohms plus the resistor wire (0.9 ohms) gives a total coil resistance of 2.8 ohms.
If you keep the Bosch coil, be sure to bypass the resistor wire.
PerTronix recommends a 0.6 ohm coil for the Ignitor II with NO resistor.
John
