A little help with what or where this block came from???
dukepol
Go to solution Solved by TobyB,
Hello forum
long time 02 guy. Know some of you on sight from buying and selling parts.
I have had this engine for a long time. I am in process of rebuilding for my 1970 1602 motor that is getting tired.  It is a non matching 1600 engine so just want upgrade to this 2.0.  Have new header, new intake for a new Weber 32/36, electronic ignition and a few other fun parts. If any can tell me what or where my block came from that would be great.
  • Solution
That's a reman from BMW-
Steve will decode all the numbers, but from the
milled- off surface and the 21, it's at least 0.25mm over,
and for the US market.
  • Like 3
As Toby said, remanufactured in August 1978 (“08  8”), or August 1988…
Read the following for more information.
Engine code “21” = 1974-75 E12-head engine
Serial number “0074” = 74th engine remanufactured that month(?)
”A” = remanufactured engine
The casting date on the block, and possibly the casting date on the head — if it’s been mated to the block since the remanufacturing — might help establish the correct remanufacturing decade.
image.thumb.png.dde368c7938e6fdccd09df042e85c630.pngYour car's color is appropriate for the background...
Thanks for all the info.  I have a different E12 head than what came with engine. I have had around 12 or 13 02’s over the last 30 years. So lots of spares. This 70 is last one I own and my daughters are instructed to use as my final resting place when time comes since all 3 refuse to learn to drive a manual😀. Their loss. Once again all great info.  Happy New Year and safe motoring. Duke
  • Like 3
And the block was cast January 8, 1975 (“8A” within the raised oval frame, and “75” just outside the frame). Thus, the block probably began its life in a 1975 2002, or was cast as a replacement block in 1975.
Good luck with your build!
