Repa rear seat belt bolt size
Hello everyone.
Recently I bought a complete set for rear Repa lap belts but they didn´t came with the bolts.
I don´t know if the size or thread are different on the latch side or the buckle side, so i marked them with different colors on the picture that i found on the forum.
I just want to know what bolt should i buy to same me the trouble of testing different ones till i find the correct one.
Thank you for any help.
Bmw 1502 1977 "Korall"
7/16“ is standard seat belt bolt size. The bolts that secure the belts in the middle are 25mm long shoulder bolt (see pic).  Not sure the length on the ones holding the retractors, but they are about the same length, standard bolt, not shoulder bolts.
Edited by bergie33
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
Yup as Karl said 7/16 the thread is unf 20 per inch. If you need to you can use a small spacer cut from steel tubing to replicate the shoulder bolt.
Edited by Son of Marty
George S Patton
It shoulder needs to be deep enough to allow the seatbelt mounting and the 2 washers that let the belt swivel up and down so something like 3/8th of a inch.
George S Patton
36 minutes ago, Son of Marty said:
I don't have a measurement on the washers but they are not real thick
Nothing special about the washers.  The "standard thickness" flat washer for a 7/16" bolt will work just fine.
