Throttle rod/cable issue.
Go to solution Solved by John76,
Recently got stranded with no pedal response only to find out the metal rod on the throttle assembly from the carb to the firewall. Shorter rod that pokes into the firewall area and attaches to the carb. Has started intermittently falling deeper into the firewall area and undoing itself.
running a 38 Weber.
any ideas or solutions are appreciated! I am trying to attach a video as well
Edited by American Mister's 2002
Typo
For future reference,  this month we will be producing our first batch of downdraft linkage kits for the Weber carburetors.  The kit will replace all of those worn components including all the parts from the firewall bracket to the carburetor throttle lever.  The firewall bracket will feature a Heim joint, the throttle lever will fit both 32/36 and 38/38 carburetors, the down-rod lever will be positioned away from the heater hose, and the entire assembly will be made with more robust components than the original versions.  Here's a few pics of the un-plated prototype version.
We'll post it on our website as soon as it is available.
www.2002sonly.com
  • Like 5
BMWCCA  Member #14493
www.2002sonly.com
www.2002sonly.com
Hallelujah! My current "temporary" solution has a bunch of friction, old springs and plastic zip ties.
