Transmission tunnel size on early cars
Dionk
Does any one know if the transmission  tunnel on a 68 1600 (sept 67 build) is more narrow then later models -
i just measured my 68 and it’s about 8inches where  my 71 is closer to 9.5 - hard to measure and take a picture at the same time.
71 2002 picture (dirty ) 68 1600 (cleanish)
Both my '68 cars are definitely narrower than my '72 car was. When i 5 speed swapped the '68 2002 i couldn't use the same transmission crossmember mounts that i had fabbed when i swapped the '72. If i remember correctly, i even had to make one of them bolt in so i could add it after the trans was in. The trans wouldn't go in from the bottom with the mounts in place. Very snug fit in the early tunnels.
10 minutes ago, halboyles said:
.  Are the mounting brackets perhaps moved to accommodate a 5-speed?
Apologies - should have mentioned I’m installing the getrag 245. The bracket is one from a kit.
5 minutes ago, Dionk said:
Do you recall whether you removed the old trans mounts?
I believe that I did have to cut off the original mounts.
ill be glad to make a copy of this template and mail it to you if you are interested, or something similar. I used all stock parts and I think narrowed the stock cross member too. Maybe.
