Higher Dust Caps for Strut Wheel Bearings
Brett
Here's a well-deserved thread bump and a pic of these dust caps on my Granada early '71.  Thanks Brett!
-Gary
Gary, thank you! Truly my pleasure! Helping the community that has helped me in so many ways is what it is all about!
-Brett
On 9/30/2019 at 5:04 PM, AlfaBMWGuy said:
Thanks @HBChris. Here is a reverse angle shot of my coil and ballast resistor setup.  My car seems to run and drive fine in the two years I've owned it regarding ignition, but if there are improvements to be had, I'm all for it.  Do I just want to jumper the leads to the ballast resistor together to bypass it, or is there a bit more to it than that?  Let me know if more pics are needed to determine that.
Thanks,
Gary
By the way, thanks to Chris' keen eye, my ballast resistor is no longer part of the circuit with my blue coil.  The resistor is still attached to the fender for the correct factory look, but the wire leads aren't connected.  I suspect I never noticed this original owner modification before because my Pertronix electronic ignition was able to deal better with the reduced spark than points would have.
-Gary
Edited by AlfaBMWGuy
  • 3 weeks later...
Running one more production run of the Dust Caps if anyone is interested.  Then going to focus on other 3D Printed parts - going to be making some custom console pods for the VDO Gauges, and some other parts.
Thank you all!
  • 4 weeks later...
