My trunk mounted battery shamozzle
jp5Touring
I understand many of you guys are relocating your battery to the trunk, But I don't understand why on a street car ? The trunk space is reduced considerably with that "Ultimate" duel purpose battery mount / rear shock tower brace. I've seen some battery relocations under the rear seat, but that's not the greatest place either for a street car.
That's my Nay-Say for the day,
Slavs
For a Tii it's not a bad idea, the battery and air cleaner do restrict the access to the oil filter and alternator somewhat, that said my tray is removable so really it's only a 10 minute job to get access, but it would be easier if the battery was in he trunk, I'd use a battery box myself as it sits to one side.
Slavs
Understand  why not on a street car, But then why do I do any of this ?  Mine came with the trunk set up but needed a new battery.
My battery was old, not vented correctly and needed to be replaced. So a quality AGM battery was added and a few bucks on better cables. Agreed the design is a total  trunk space hog and needs to be addressed. Luckley My oldest Son is a very talented metal fabricator, so I might mess with a better design with raising the bar or moving the battery more to right at a 90 degree.
I think the way to go is under the seat with all the new battery technology.  I have speakers there  for now but I think that will change.
One of my friends relocated his batter under the rear seat. He used an Optima battery which can be mounted on its side to prevent a potential hazard of the seat springs and frame coming on in contact with the terminals. He used cables from a newer BMW he found at the junkyard. I think it was one of the e30 series. He never had any problems with it.
I was going to do a trunk mount, then thought about under the seat, then decided if I was going with a small battery, why not just put it in the stock location?
3 lbs, 1/4 the size, and I don't have to run cables throughout the car (long cable runs are not ideal for a smaller/lower cranking amp battery)
EFI and a turbo are in my future plans, so now I have lots of room for tubing
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
Hi,
If going with EFI, that particular area where the battery is mounted is perfect for the air filter housing.  I installed an e30 airbox there, but a battery would have left room for it.
