gauging interest in TUNE BOX run
PatAllen
1 hour ago, Fortlauderdalian said:
Is there a trick to using the box to start the car? I get the read out but doesn't start.
theres no trick.
check if one of the wire has fallen out of the diagnostic port on the car side. i saw this happen, remember the car is 40+ years old
should work as is.
1985 XR4TI, 22psi ±300hp
Just saw Pat's caution "MAKE SURE THE TRANSMISSION IS IN NEUTRAL".
I use my tune box for setting valves.  Only once did I forget.   I drove onto the tip of my shoe.  I was lucky.
DON'T FORGET TO MAKE SURE THE TRANSMISSION IS IN NEUTRAL.
Edited by PaulTWinterton
73 Inka Tii #2762958
10 hours ago, Fortlauderdalian said:
Checked all the wires and neither car starts from the box. I can hear the fuel pump running on the Tii
it will be very hard to troubleshoot from a distance like that, considering that i cannot verify aything on your cars. seems you have more than one car to use the box....i need to know if the wiring on the car is 100% stock or has it been ever modified, cut or wathever ?
100% of my boxes are tested on a jig that simulates the car, so at this time i am completely clueless.
While car is in neutral (or in PARK if its automatic) , try shorting thoses two pins (see picture) with a piece of wire or long nose pliers....it should engage the starter. if not then theres something wrong on the car.
i see the pins on your plugs are heavy corroded...try shooting a bit of WD40 on them too.
Edited by PatAllen
lool it happened to Rob Siegel too as he mention it in one of his books....
