The 245 5 speed conversion ups the value -Yes or No?
Tdh
On 3/16/2019 at 3:21 PM, halboyles said:
Here is a cheat sheet I put together for the 5-speed conversion in the early '80s at Simpson Motorsport.  Should have bought a dozen or so at the time.
Hal this is amazing. Is this for the Getrag 235/5? This saved me quite a lot of searching if so.
Thanks!
Value: hmmm....
I really liked my 4 speed when it was mated to the 3.64 differential.
I really like my five speed mated to my 3.91 LSD
After experiencing both, If given the choice I really dont know if I would pay more for one over the other.
To me the 5th gear is to helpful to compensate for the differential ratio change.
I am having fun with the LSD, don't get me wrong, it is a tad more spritely.  But it wasn’t cheap ( 245 Getrags and LSD’s getting more expensive every day) and I’m really not sure after all the investment, if the  the dollar/grin ratio was worth it.
A 245 (for me) will add more value only if it is mated to a 3.90/3.91 differential.
But I ain’t no expert.
Edited by Vicleonardo1
1975 Malaga. It is rusty but runs. Just like me.
FWIW (and we've already determined that it's worth dick, so I'll just offer my own opinion/musings here ;) ) my '76 mintgrun got a DIY 5 speed swap four years ago after owning it since 2002, and that is definitely in the top 3 of upgrades I've done in terms of driving enjoyment: recaros, suspension upgrade, 5 speed. Worth noting that for the first twelve years I focused on cornering upgrades vs a 5 speed, and not a single regret as I love a spirited drive when I can find it. (but damn I love having the 5 speed for highway cruising)
Now, the '73 sahara I picked up this past Fall from the original owner (in the photo) is a numbers matching survivor. As will be with any vehicle that had limited driving for a while it's got a number of issues around oil and transmission leaks that still need to be addressed. In the Fall when changing the tranny fluid a metal piece came out that was bigger than a fleck, which has me a bit concerned for how long this original 4 speed will keep running, even after I replace all the seals on it this Spring.
I've been contemplating whether I would 5 speed upgrade if indeed the tranny goes bad, and I still don't know, but I'm a bit more compelled to try and keep it original on this one... Maybe it's because I already have one that I've done mods to and this is "the original" car I have, maybe it's because it's a number-matching roundie that's unmolested and almost all original and it seems like the "right" thing to do. Not sure.
'73 Sahara numbers matching
'74 Mintgrun sunroof car w/ oem Golde deflector, euro bumpers, 5spd, owned since 2002
Hey Otto,
I think you did realize the benefit of a five speed for your 76, because if it was a 49 state car, the differential was a 3.90. That would make the RPM's at highway speeds a bit bothersome and the 5th gear certainly would help.
For the 73 Sahara, not sure if the 5 speed swap would add much more to your driving experience unless you spend a lot of time on the highway. I am sorry, I cannot remember what the RPM drop would be at highway speeds when mated with a 3.64 differential.
But if you find the Sahara annoying on the highway, then I would do the swap. For me it is much more fun to enjoy the car and drive it than to have than worry about future value.
But what do I know?  I ain't no Toby......
