Hold down bolt for dizzy
Evening everyone - can someone help me ID the bolt size that tightens the dizzy in place after adjusting timing? From the looks of real oem it's a little difficult to distinguish bolt 2 from 11. Also, are there washers involved?
5ac8342bacac5_ScreenShot2018-04-06at10_55_08PM.thumb.png.484b344b4d70c7cc5c90ec6bfad7b857.png
5ac8352ef37b8_ScreenShot2018-04-06at11_01_16PM.thumb.png.76eedceab7e8faa8cd7d4b49c7da1a86.png
Series 1, 1969 2002
Instagram: joseiden_bmwerke
Bolt #2, washer #3, washer #8 and nut #9.
Distributor
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Gasket Asbestos Free   1     12111734032 $1.67
02 Hex bolt M6X45 1   07/1977 07119912327 $0.22   ENDED
02 Hex bolt M6X45 8.8 ZNS3 1     07119902976 $0.45
03 Washer 6,4 1   07/1977 07119931044 $0.58   ENDED
03 Washer A6,4-ZNS 1   07/1977 07119931018 $0.40   ENDED
03 Washer A6,4-ZNNIV SI 1     07119904202
04 DISTRIBUTOR FLANGE   1     12111252932 $70.62
07 O-ring   1     12118530508 $1.67
08 WAVE WASHER B6 4     07119932072 $0.09   ENDED
09 Hex nut M6-8-ZNS 1     07119922832 $0.37   ENDED
09 Hex nut M6-8-ZNNIV SI 1     07119905543 $0.38
10 WAVE WASHER B8 1   07/1977 07119932095 $0.09   ENDED
10 WAVE WASHER   1     07119904115 $0.09
11 Hex bolt M8X30-ZN 1     07119913662 $0.22
12 Hex bolt M6X50 3   07/1977 07119912337 $0.91   ENDED
12 Hex bolt M6X50 8.8 ZNS3 3     07119902993 $0.59
13 OIL PRESSURE SWITCH M12X1,5 1   07/1977 61311354274 $14.96   ENDED, +core
13 OIL PRESSURE SWITCH   1   07/1977 61311354273     ENDED
13 OIL PRESSURE SWITCH M12X1,5 1     61311243414 $13.31   +core
13 OIL PRESSURE SWITCH M10X1 CON. 1     61311351799 $11.99   ENDED
13 OIL PRESSURE SWITCH 0,2 -0,5 /M10X1 1     61311350385 $11.38   +core
14 Hex bolt M6X20 1     07119913477 $0.18   ENDED
14 Hex bolt M6X20-8.8-ZNS 1     07119913016 $0.60
15 Washer-gasket ZÜNDVERTEILER 1     12110002735 $1.71
6x1mm thread.
