sunroof felt install question
mvliotta
Hi '02 land,
After reading some posts on sunroof felt installs, not clear whether you MUST remove sunroof to install the front and back felt strips.
Understand that the front felt should be attached to the car and the back felt attached to the roof. Can you (should you) try with sunroof panel in place? If I need to take out the panel, do you have a link would you recommend so that I don't botch it?
Thanks!!
Vince
'72 2002tii 'Liesl'
You can install the front and side weatherstrip section (one piece) by simply cranking the sunroof all the way open.  Use contact cement or weatherstrip adhesive to hold it in place, and don't forget to wrap an inch or so down behind the side ends to insure a tight seal between the side piece and the back piece.
The rear weatherstrip is glued directly to the sunroof panel itself, so that must come out.  If you can't find instructions for removal and replacement on the FAQ, drop me a PM; I did a how-to column on that very subject and will be happy to send you a copy.
cheers
Have to remove the sunroof panel to install the rear seal to the panel. Take photos as you go. search mytii.com, though Keith installed the rear seal incorrectly on the roof panel.
Wind the sunroof rearward, pry down on the leading edge headliner, held by 4 clips, push the headliner rearward.
Remove the 4 Phillips head screws at the front of the panel, note where the glide is located and its orientation.
Wind panel forward a little and remove the screws holding the cables to the panel.
Lift out panel.
Installation is the reverse of removal.
Andrew Wilson
