Would this be a good first 2002?
Frank Vogel
How would I be able to tell if it were a ti?...]
For starters, it would have to be manufactured from late '68 to early '71 to be a factory ti. Second, you'd type the VIN into the VIN decoder of the BMW 2002 Car Club of Columbia and you would know immediately.
http://www.bmwclasicos.com/vin.php
And if it showed up as a ti in the VIN decoder, you'd confirm the decoder's answer with an email to BMW Archives requesting their data for the car, free of charge and often supplied within 24 hours (info.grouparchiv@bmwgroup.com).
Since they were never "federalized," and sold officially into the U.S., you probably will not run into many (a handful have found their way here over the years)! :-)
Good luck,
Edited by Conserv
Not very hard.  It is a little awkward working around the driveshaft, but not bad.
Blunttech sells a shifter refresh kit.
There are a couple little 'while you are in there' things you can add to the list, if there are transmission leaks in the area; such as a shift selector rod seal and speedometer cable o-ring.
I have read that the shift selector seal can be pushed in right over the old one, assuming this has not already been done.
The only mistake is to buy the first one you've ever seen.
Did you make the-only mistake?
(I did... but I don't regret it... even though it had almost all of the typical 'needs').
I would say there is one other mistake... which is to ignore the rust you find.
must    fix the rest    of the rust!
