Bmw M10 Connecting Rod Bearings Third Undersize
jcnnjc
Does anyone know where they sell this size, I can only find 1 place and thats BMW they want 13 bucks each
My motor is a factory replacement motor and it had 1st over on mains and 3rd over on conn rods
will have to find a new crank if I cant find bearings?
Thanks
Jim
1970 2002 gone
1972 2002 gone
1973 2002 gone
1974 2002 just started resto
2002 Mini Cooper
1997 Bmw z3
1970 2002 gone
1972 2002 gone
1973 2002 gone
2002 Mini Cooper
1997 Bmw z3
absolutely bizarre. Give Ireland Engineering a call; they should be able to get you bearings in most sizes.
1974 Grey European Market BMW 2002
1976 Yellow BMW 2002 "GOLDENROD" SOLD
1972 Yellow Austin Mini 1000
A bunch of Bikes...
Make up your mind.  Are the bearings oversized or undersized?
The way I see it, when a crank has been ground, it is obviously undersized and then requires an undersized bearing-shell.  We’re talking diameter here, not shell thickness.  And yes, bearing shells are sometimes sold individually.
Too many cars.
Rockauto lists Glyco as still having .75mm undersize.  They usually have what they say they have, unlike a lot of others.
$50.  They've been around a long time.
Try Blunt, too.
Try Blunt, too.
will try rockauto Thanks!
1970 2002 gone
1972 2002 gone
1973 2002 gone
2002 Mini Cooper
1997 Bmw z3
