Broken Passengers Side Motor Mount Bracket
gliding_serpent2
4 minutes ago, jp5Touring said:
Anyone know the gap needed on the passenger side motor mount for the limiting bracket ?  I need to install one but can't find any specs on them, thanks
If you mean fore and aft, I'd look at the gap between your fan and the edge of the upper radiator tank.  Whatever that gap is, the limiter should be less.  To clarify that statement: I have a tropical fan and its circumference is outside the actual radiator core.  A standard fan may spin inside the upper and lower tanks, therefore you'd measure the distance from fan to core.
Regardless, 3mm gap between rubber mount and limiter should be adequate, IMHO.
If you mean up and down, I'd measure the thickness of the limiter and lift the engine at least that much, with the P/S mount bolts removed.
TIP: If you are having a tough  time re-aligning engine onto mounts use a drift (icepick/centerpunch...) to line up one hole while inserting a bolt into the other hole.
73 Inka Tii #2762958
