Sudden Pulling To The Left Post Braking.
gliding_serpent2
Tracked my car 2 weeks ago.  Did not drive it much since (maybe 30 min drive 2 days ago).  I am driving to work this am and suddenly after moderate braking the car starts pulling to drivers left.  I engage the brakes a few more times and it settles and soon disappears.  Not long later the same thing again post breaking.  This time a slight pull left remains.  No obvious squeal.  No big bumps hit.   I pull over and front calipers are cool and both rear drums are equally mildly warm.  It is a cool morning.  I did not get a good look at the pads.   A solid 1.5 hour sporting back road drive later with no issues at all.
My theory is brake dust in the pins and the front calipers getting mildly stuck.  I plan to disassemble, polish the pins as needed, and re-grease.
Any other thoughts?
UPDATE: brake lines are brand new stainless that were installed the week before track use.
Edited by gliding_serpent
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
I would agree with it getting sticky. since it pulls to the left after you release the brakes, I would investigate the left caliper and hoses.
edit: as mentioned above , check hose condition as well. sometimes they deteriorate enough to collapse internally and not allow the pressure to be released.
Edited by mikebontoft
Brake dust theory unlikely--did you change pads after track and then this started happening? If you still have rubber lines replace them as most likely they are now one-way valves. If already stainless braided then unusual. let us know what you find.
--Fred
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
How old are the flexible lines to the front calipers?
GL,
if the car is being tracked, i am hoping the answer is nearly new, along with the caliper seals.
i would be taking the rear wheels off and checking rear brakes and ebrake mechanisms.
and...check play in front wheel bearings.
2xM3
- Pads were not replaced post track, although I do have a new set of potterfield R4-s pads to install when I get new front rotors.  Ample pad left on the fronts.
- brand new stainless lines the week prior to using it at the track
- unsure about caliper seals being old or new.  Brakes were given a thorough check this spring.
p.s. in an older post I used to have slight brake dive, but that was 100% fixed with the new lines.
