Help- Flickering lights
MicahDolen
...Yes I searched.
My head lights and dash lights are flickering. They do it more at idle but also at higher RPM.
I have check all my grounds. I have installed separate relays for high and low beams. I also have a 320 alternator and a fresh optima battery.
It was a used alternator, can the flicker come from the alternator itself?
Any ideas would be helpful
Thanks
Voltage Regulator? Have you used a voltmeter to check how much the car is doing at idle?
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Like Konrad said. Check the volt. reg in your 320 alt. It's SUPER easy to get to you should be able to do it w/out taking anything off the car. I'm almost positive that it's 2 phillips head screws.
If it's bad, it will be pretty obvious. If they are bad call blunt. the part is cheap so buy two (one for a spare)...Trust me on this...
ALSO before you start the car up, throw the battery on a charger and get it all juiced up.
Dave
Pittsburgh, PA
67.5 Datsun Roadster
72 2002 Colorado
89 325ix
99 318ti
04 x5 3.0
